Thanks...
Don’t plan on using the transfer case from awd. Just wondering if the 4x4 t-case will bolt to the Yukon tranny
When did they change the length of the output shaft?The transmission will bolt up, the flywheel should be the same, and I would use the torque converter from the donor transmission. I think the electrical plug and wiring are the same.
