Assuming you referring to long block to long block
Yes it will drop right in
Use your original motor mounts
Orginal intake, oil pan (as long as the low level float is is the new one)
All Orginal accessories
You will need a DOD delete kit. (8 new lifters, lifter trays, head bolts, head gaskets, valley cover)
And the Lengenfelter 58x to 24x adapter. This will extend any wiresvthat are need also.
