Hey all and sorry for the novel!
I have a 2012 Tahoe LTZ with a 5.3 and 178k miles. We recently had the check engine light come on with P0521 (I think) as the code which is oil pressure sensor. The oil pressure has always been "low" since we've owned it, but recently it would start below 20 psi at cold idle, get down to maybe 15 psi at hot idle, and never got above 25 psi while driving. I've never noticed any ticks or anything as long as I've owned it.
What I've already done:
1. A little over a year ago (February 2022), the oil pressure sensor stopped working completely. The gauge read 0 psi all the time and threw the P0521 code. I put a new AC Delco oil pressure switch and Dorman screen in.
2. This past weekend (March 2023), I was due for an oil change so did a motor flush with the motor medic stuff. I also dropped the pan and replaced the oil pickup tube oring.
3. I'm not going to lie, there have been at least 2 occasions (probably more) where I haven't checked the oil as often as I should have and when I did it either barely registered or didn't register on the dipstick. One of these was last week, but topping off the oil didn't really change anything.
The pressure now, but still not great in my opinion. Cold idle is around 35 psi. Hot idle is around 22 psi. Running (hot or cold) it stays around 35-40, responds to throttle (ie decrease when coasting and increases when accelerating), and never drops below 30 while moving. It hasn't thrown a code in ~100 miles since this past weekend.
I have used Pennzoil High Mileage Synthetic with Fram Xtra Guard Synthetic oil filters as long as I've owned it. Don't kill me, but I change the oil when the truck tells me to (I think it's 7,500 miles).
What do you recommend I do next (in order of cost/ease for me):
1. Do nothing, everything is fine. I've seen some posts on here that have said this behavior is perfectly normal.
2. Change the oil/filter (or just the filter) at 3,000 miles or when the oil pressure gets scary.
3. Change oil and/or filter to something else and/or use a different weight oil and/or oil additive. Not trying to get into a chest pounding session here, but open to ideas if others have direct experience with this fixing this problem. I'm not convinced that the motor flush and/or the oring swap did anything, it may have just been the oil change that increased my pressure.
4. Change the oil pressure sensor and screen again. It's only a year old, but $50 and some scratches/bruises/cussing is easy and cheap.
5. Change the oil pump. Thinking that perhaps between running the engine with low oil and/or a bad oring, I've trashed my oil pump. I am seeing some small surging of the oil pressure all the time. Nothing major, maybe +/-2 psia when RPMs are rock solid (idling or cruising).
6. Sell the truck. I consider this the nuke button since I like the truck, but I don't think I'm willing to dig in deeper than the things above. Not interested in (myself or a shop) removing the DoD/AFM, changing the cam/cam bearings, etc. The juice isn't worth the squeeze for my situation.
For "Change the oil pump" above:
-The old oring was orange and the new oring was also orange so I thought I was good. The old oring had flat spots on the ID and OD, but wasn't split or as brittle as I thought it would be. I was also surprised that the new oring went in as easy as it did. I was expecting/hoping it to need some hard pushing to get it in, but it just kind of slipped in (maybe that's normal). With the oil pump change, I could use the thicker oring (like the green one that comes with the Melling oil pumps). My pickup tube has the tapered end, not the straight end. If I dig into it again, I will use a new Melling pickup tube as well.
-What oil pump should I use? I've read that (at least) the LTZs have a stock high volume pump because they have the towing package and oil cooler. Is that correct? I'm looking at Melling M295 (normal volume/pressure), Melling M295HV (high volume/normal pressure), or Melling 10295/10296 high volume/pressure.
-Should I change the oil pressure relief valve as well while I'm in there? I think it screws into the pan. I'm looking at Melling MOPR100. Are the oil pressure relief valve and the oil filter bypass valve the same thing?
Thanks!
Thanks!
