5.3L Starting Issue
SGinn722
Memphis
I have an 08' Yukon with the 5.3L. Within the last 6 months or so my truck has begun to act as if the motor doesn't want to fire when the starter turns over. It usually always does crank but sometimes the starter has to turn for a good while before the motor cranks. Other times the starter barely turns and the motor bogs down and barely cranks. Once it's running it runs perfectly so I don't think it's an issue with plugs/wires/coils. I replaced the starter but wound up wasting my money when it didn't fix the problem. I've heard of others having similar issues but has anyone definitively found what the problem is? It's more annoying than anything else. Never used to do it.
Physh1
Sounds fuel related, especially if there is no SES light. Try changing your fuel filter...if that doesn't help your pump may be failing but, ideally, you'll want to do a fuel pressure check.
Cameron
SBCT
Battery
Sent from my XT1080 using Tapatalk
SGinn722
SGinn722
Memphis
I had it in my head to start simple with the filter. I'll change it and see what happens. If that doesn't work I'll have to take it to my mechanic. I've had the electrical system tested and everything checks out. Battery is strong and holding voltage. Thanks,
SBCT
Definitely sounds like a possible amperage problem with your battery.
Dieseldr
