5w40 in 03 Yukon XL Denali?
DROCK84
Illinois
I just purchased an 03 Yukon XL Denali, brought it to my mechanic to change all the fluids when he recommended I return the Mobil1 5w30 Full Synthetic High Mileage I just purchased and buy 5w40 Synthetic instead. I'm confused, why would I change to a German Gas/Diesel oil instead of the normal 5w30??
Has anyone had any problems using 5w40 or has anyone heard of this before?
Thanks
mizzouguy
Lake of the Ozarks, MO
I've heard of people switching to 10W-40 conventional if their engine is pretty worn and leaking/burning oil. Or even 15W-40. And I know they make 10W-40 in synthetic although not many places carry it. So not sure why he would say 5W-40....like you said european/diesel...I think you would be better off sticking with 5W-30 or 10W-30.
TommyR
I run 10w-40 in mine with no issues. I have lower oil pressure when its cold due to how thick it is, but thats it. My mechanic recommended it due to oil dripping through the valves. If I was idling for a minute or more I would blow blue smoke everywhere. Fixed the problem about 90%.
SirReal63
Bertram, TX
I run 10w40 in my 03 2500HD, have for years. It is also at 314k miles, I started doing it before the oil pump was changed, and it did help to quieten it down.
Umm...did you ask your mechanic why he suggested that?
RST Dana
OH
We used to run Kendall 50W in all of our toys. This was before synthetic was born.
DROCK84
DROCK84
Illinois
I did, he told me because I have 217k on it that if I put in 5w30 synthetic I might get oil leaks from worn out gaskets or rings. He "required" 5w40 synthetic as a way to help fight that issue and says he puts it in all the cars he works on that call for 5w30. Also, I believe he wanted to use the 5w instead of 10w due to how cold the weather gets around here.
dacpdx
