65+ MPH rear wobbles
slipping
slipping
Rosamond, CA
It did better after I tightened ubolts, but still has slight rock. I visualed the center pins and they did not look to be out of tolerance.
But this is why I'm changing shocks out
___________________________
99 4 door Hoe lifted
04 Hoe stock
94 z28 lowered, being referbished
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
A couple of weeks ago, I finally wound up having some free time to work on the Yuke... the front clip, bumper, and grill guard were all tweeked from the PO... and I wanted to get under it and tighten everything as suggested.
While under it, I discovered that the driver's side torsion key was cranked in about 1" - 1.5" more than the passenger side... so I let it out - ride is much softer and truck sits laterally level now... also that the driver's side sway bar end link was bent and the lower nut and bushings had fallen off - so effectively no front swaybar...
I'll be buying the new end link tomorrow
slipping
slipping
Rosamond, CA
Yeah. Haven't been driving it really. Ordered new one. Kinda got wide eyed when I saw it. Posted in another topic about dropping Tahoe though. Thanks man!
ArcticYukon
Dry Ridge, KY
Just replaced the front swaybar end link... sway is gone other than the expected side-to side- motion that's typical of any lifted truck
FooglePhish
