$65 Phone Mirroring to Dash and Rear Screens
bjurkovski
  • wiring.pdf
  • wiring.pdf
jl449
Salinas, Ca.
I can't seem to get mine working after splicing into the wiring harness behind the rear center console. I followed the attached wiring diagram and sliced in an iSimple HDMI converter (http://www.amazon.com/iSimple-ISHD01-MediaLinx-Composite-Adapter/dp/B00LUX1F5K). It worked when I tested it connected directly to the RCA inputs but no go after hard wiring it.
Double check your pins... pin 6 (signal) and 12 (comm) for video. 4 (A/R) 5 (A/L) and 11 (comm) for audio..
See this post for clarification:
http://www.tahoeyukonforum.com/threads/2015-hmi-unlock-video-in-motion.71560/page-3#post-892572
PB&J
jl449
Salinas, Ca.
I just saw the review of the isimple medialinx on youtube...
I would think chromecast will work but the chromecast will require power thru a USB.
Weber Dude
Yep, I saw that as well. I receive the isimple medialinx yesterday. I'll see if I can get around to trying it out this evening.
Weber Dude
Just an FYI, the Isimple Medialinx works. Wasn't having luck getting the chromecast to work so I got an HDMI cable from work and plugged in my lightening to HDMI adapter, then plugged my phone into that. Phone mirroring works. Now I can play Netflix for my little girls. Just need to get a short HDMI cable.
jl449
Salinas, Ca.
Chrome cast doesn't work? I had an issue with it plugging the USB (powering the Chromecast) to OEM USB. The SUV USB ports didn't have enough power. I ended up getting a 2.0 A usb charger and plug it in the cigarette plug. It worked.
Weber Dude
Thanks. Didn't even think of that. I think I might have one of those in my wife's car. I'll need to check later when she gets home.
