6l80 interchangeably (putting 2017 trans into 2011)
Donnyd21
I have a 2011 Tahoe, I have access to a 2017 6L80, could I use the 2017 transmission in my 2011 if I swap my TECHM and valve body over to it?
D
Donnyd21
probably not, but also not 100% sure. they did make some changes
I could understand the valve body and obviously TECHM but I plan on swapping those over to it so no reprograming is required
I really don't know but i found this
D
Donnyd21
From what I can find the ONLY difference is the TECHM and torque converter. ALL other internal parts are the same (using rock autos parts listing). I plan on rebuild my TECHM and ordering the correct OEM torque converter for my 2011, should be good to go.
Sparksalot
Bastrop County, Texas
The newer transmission will have a thermostat on the side where the remote cooler lines attach. You’ll have to probably put new fittings on the current lines to connect up.
D
Donnyd21
The lines on the 2011 will bolt right up, the transmission cases are the same luckily
Fless
Super Moderator
Elev 5,280
I'm at this same point. Any update and useful information?
this thread ancient, id start another with your specific situation vs performing a necro.
The OP hasn't been on here in at least a year.
In your new post, please give specifics about your year-make-model and the same info about any potential donor parts.
Joe03z71hoe
