PG01
Id take a test lite to your 7 pin.... each pin is labeled, have someone step on brakes as you test the pin then disconnect the harness from behind the 7 pin and check it there.... trailer connections get corroded so check ur ground back there tooHello Everyone
I'm new to this forum. I have a 2004 Yukon SLT that is having the exact same problem. I was hoping someone found a solution.
