Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Why am I not getting ground to my 7 way trailer plug I can touch tester to frame an get ground. My dad plunged in a winch with the hot an ground reversed would that have messed it up. still have hot with tester to frame
Are you sure that you don't have ground at the 7-blade? Plugging something in backwards there would blow a fuse, I would think. Checked the fuses under the hood?
The 12v should be either that or #4, depending on how the winch was wired. Those are the two heavy conductors in the 7-blade. The others wouldn't power a winch, and they're essentially switched with the lights and fused a lot lighter.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
