#8 Cylinder Spark Plug = nightmare!!
BRUTUS_T_HOG
Since we are reviving old threads..... I use a flex ratchet and 1" extension on my spark plug socket. The hardest part is enduring the razor sharp heat shield
jz57
Lift front passenger side with floor jack and jack stand, remove front passenger-side wheel, band down heat shield underneath A/C accumulator, you have plenty space to access #8 spark plug. No fancy or expensive swivel spark plug socket set. Take you less than 1 hr to get job done, including wheel removal/installing.
When the front passenger-side wheel being removed, all passenger-side spark plugs can be accessed with regular Spark plug socket and some extension bar.
Don't spend over $100 tool for that single #8 spark plug, since you don't replace that spark plug more than twice in your truck's life span.
The basic tool you need:
Spark plug socket
3/4 drive 19MM Deep socket (removal/installing spark plug)
3/4 drive 19MM shallow socket (for hand tightening the spark plug)
3/4 drive ratchet
Floor jack & jack stand
Some Rubber gloves
Will post pix if members prefer.
patniven
