8-High MOD - HEADLIGHTS
jmildoc
Indianapolis,Area
I may have done it backwards. I definitely blew the relay. the diode also melted in two!!
I am also not sure of the correct diodes to use.... and which pins to place them in to get the power to be constant
withac
Eastern Idaho
What year is your Kon?
jmildoc
Indianapolis,Area
Its a 2000 as well, For my four high all i did was ground a wire so that the lows stay on with the highs. Will your fog mod keep the fogs on all the time?
withac
Eastern Idaho
Whenever your yellow marker lights are on, so when the lows come on so do the fogs and when the brights come on the lows and fogs stay on. It's a piece o' cake to do
Dalton
louisiana
i just did the 4 high on my '03 (i dont have fogs) i tried to jump pin 85 from the low beam relay to pin 85 on the dtrl relay and it didn't work, which pins do i need to jump to get my dtrls to come on with my low beams?
tucsonlocal
laguna beach, ca
With all those extra lights in front it looks like you could be the first to do the 12 high mod. It would look like a freight train coming!! LOL..
Dalton
louisiana
figured it out, same old pin 85 to pin 85 for the dtrls to come on with the lows. i just had the diode in backwards (soldered them to wire leads and covered with heatshrink didnt mark the silver bands direction)
hosleyb
