Dantheman1540
I have 295k on my 3.73's. I THINK o serviced it once since I bought it at 212k--I THINK. I try not smoke the tires too much.
Need to give it some WOT neutral drops and see how she like it
JK don't do that
Lol, even when I was a kid I never did that--except for the Camaro I was dumping. I coukdn't kill it tho. I didn't even hurt it.Need to give it some WOT neutral drops and see how she like it
JK don't do that
Any way you could take a picture of it? It's possible someone swapped it because I have looked under a considerable amount of GMT800 SUVs and never seen anything other than a 10b, unless of course it was a 2500 SUV but I don't believe the escalades came with a 2500 version. Then again GM did some funky stuff back then so if you found a unicorn I want proof!
About your current rear end, it's not wear over time that gets them it's the locking mechanism in the G80 that doesn't like sudden loads and is known to expload. If its quiet and you don't plan to put big tires/heavy wheels or stomp the gas constantly it will probably be okay for awhile. The 4l60 however probably won't.
I meant to attach these pics last night when I replied. Here are the pics I have of it. Yeah, not a 2500 as it's an Escalade. Perhaps a unicorn??? Part of me wants to go grab it, but fact that it's been eff'd with already is keeping me from pulling the trigger on grabbing it just yet.
Stock 17" wheels and tire size currently and for the foreseeable future. Tahoe is my daily driver and long trip car so I'm keeping it mostly stock. The trans is on the docket for being attended to at the same time as the 6.0 swap. Believe it or not, it's the original trans with that mileage and still running. I can make it slip if I try and it is tired. The plan is to convert it to a 4L65 and whatever other strength adders are possible once it's out. All ears on suggestions for that one as I haven't researched much on that, other than the 5 planetary swap going to 4L65.
View attachment 272957 View attachment 272958
I did some Google searching and found that @mattt is for real and they do exist. I think it's just 2wd NBS Escalades. Heres one on Ebay for sale
https://www.ebay.com/itm/Rear-Axle-...-/143937297385?_trksid=p2349624.m46890.l49292
spent the day googling 9.5 inchers huh?
Do either of you know what gear ratio would've been offered in that 2wd Escalade 6.0? Were there multiple ratios available, or only one ratio in that combo? Thanks. Still mulling this one over since it's been opened up. If it were unmolested, I'd likely go snag it for future.
So I have now seen another GMT800 14 bolt rear axle. It's in another 2wd 6.0 Escalade that recently showed up in my local LKQ yard. This one is still complete as of yesterday. Tempting to grab it for future use when my 330k miles 10 bolt dies, maybe after the 6.0 swap. I did confirm it's the right 3.73 ratio that my Tahoe has (GT4), but no G80 in it. It would run me about $350 to get it out the gate there, don't need it now, but may in the future if/when the factory 10 bolt rear gives up the ghost. What's anyone have to say, keep the 10 bolt, or swap in the 14 bolt? Any downside to changing to a 14 bolt?
So I've now seen a 14 bolt rear axle in a 2005 and 2006 Escalade 2wd w/ 6.0. I wonder if GM used it in 2004-earlier 2wd Esky's as well...time will tell.
Anyone seen this special edition on a 2005 Escalade before? I searched and came up with nothing. The lettering is on the driver's side of the rear hatch and appears to be factory. I can't find anthing on it though. "RCA" Hi-Fi Edition???? LOL!
View attachment 276984 View attachment 276985 View attachment 276986
