92 Yukon 5.7 (New engine w/ 20000 miles): Engine Oil??
TerryKing
Vermont, USA
Hi Everyone,
I have free access to some Shell Rotella T4 oil 5w-40 which is high quality recommended for diesels.
Any reason I shouldn't use this in my regular GM350?
Thanks!
TerryKing
TerryKing
Vermont, USA
Hi, it's T4 15w-40. I can get 20+ quarts of this for free... Supposed to be very high quality. The older GM's didn't spec. full synthetic, although I use it in my 2012 Tahow 5.7..Thanks!
bigfootchiro
Largo, FL
Well, it does have an SM api rating, which any S rating would be ok for gas engines, but it’s the only S rating for that oil. Honestly, if it were me, I wouldn’t. $50 here and there for an oil change offsets the cost of potential harm that oil may do, in my book. T4 is great oil. Used to use it in my Cummins, but not for gas engines. If you were talking about T6 5w-30 or 10w-30, I’d say go for it and send some my way haha.
zraffz
Regardless of being a diesel or gas oil, any 15w40 oil does not belong in a freshly built sbc.
I always rebuild my motors on the tighter side if tolerances and generally run 5W30.
RED TAHOE LS
Rossville, Georgia USA
Times two......good luck.
David g.....:)
It's not so much all those ratings and standards to watch for but the viscosity of the oil as Josh said. Use the viscosity it was designed for unless you've redesigned it. I think those were 5W30 or 10W30 back then. The diesel oil would be too thick.
meow
