93 blazer random stalling
93fsblazer
93fsblazer
Tuscaloosa,Al
Today it quit spraying out of the injectors completely. Ran fine when pouring gas into it. Noticed it has a code 51 now. So what number so I go by to replace the pcm/prom?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
93fsblazer
93fsblazer
Tuscaloosa,Al
The code didn't show up until after. But I know 100% that it's in the way it came out. I noticed that it said remanufactured, but didn't think much of it
SunlitComet
OBS Jedi-Do Good
so when you pull the prom out then the code showed up? not before? that is normal. just wanted to be sure. it is unusual for a prom to ever fail. proceed with the repair and good luck. when done go over connector and grounds again to ensure clean terminals all around. this may have happened before hence the remanned pcm you have in there now.
93fsblazer
93fsblazer
Tuscaloosa,Al
I found a wiring diagram online and I'm going to use it to tap the injector wires at the computer and again at the injectors to bypass factory wiring. If they work then I guess I have a bad wire somewhere, if not I can see if I can Find a truck like mine to swap out stuff with right quick for a test before thinking about a pcm/prom. I haven't had a chance to test the egr because it won't run right now.
Boyce0183
