93 chevy suburban idle drops
Moe007311
I recently changed my water pump and started having problems it started by plugging battery before I thought I was done I touched the alternator I had extension in my hand I touched the block and heard sparks then thought I burned the alternator it started then it died out then it wouldn't start again I changed coil and ignition module it started but wasn't firing in order then changed the spark plug wires few got burned I guess it started sounded normal then after few moments the idle will drop as its chocking and when I give it gas then it dies help please thanks
Njoppy
