Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
the drivers door is very hard to shut. almost like it needs re-aligned or something. if its not shut all the way the body lines are off a little. any ideas?
Agreed. Rather straight forward job. to check this, open the door and then try lifting it upif it moves they are bad. Watch the hinges when you do this. The door latch may also have the wear strip worn off.
The pins and bushings go bad since it is a heavy door and people lean on them entering the truck and they wear faster.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
