Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Awesome! So glad it worked out for you. Now I don't feel as bad that I had to learn that lesson the hard way.. at least I got to share it with someone else.
Keep a watch on it for a little while. Just to be certain you officially got it. Sometimes your problem may resurface shortly after (if that truly wasn't the main issue leading to it).
Have a code 32 and a 15. Occasionally won't start and some hesitation after hard start that requires the gas down all the way to turn over. It'll drive fine all day and then screws up at night.
Wow I'm surprised it's back! Sorry to hear that. :-(
Maybe since it's a temp driven thing.. Do you think you could possibly have a vacuum leak somewhere that opens up when it's cold out? (Rubber expands and contracts in temps)
Hesitation hasn't reared it's ugly head in a couple days, but the big problem is starting when warm. The truck will crank and crank, but not turn over unless I hold the gas to the floor, thinking about getting another Delco CTS and throwing that in before bringing it to a shop on Monday.
I haven't checked the IAC at all and did not replace the pigtail when I hooked it up. It seemed to be in pretty good shape. I'm wondering if disconnecting the battery might help in any way.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
