95 tahoe Blend doors
warndogg
No, probably not. The actuator is probably bad or something is physically blocking the door/flap. It should not move beyond the 2 detents on the actuator. With the actuator off you should be able to manually move the door. If you can't you will need to remove dash and fix. Hopefully you just need an actuator.
vendo
vendo
ma
i can move it with the actuator off and defrost works,can you index them if you take them apart?
warndogg
You may be able to fix the motor by taking it apart. I think there maybe might even be a post or two around here about that. Honestly If you have the cash they are under like $40 I would go that route.
vendo
vendo
ma
ok i will get an ac delco one...i just wonder if the newer a/c control using the wiring harness was the issue..
vendo
vendo
ma
my acuator is in the middle when i put it on defrost,the pictures posted shows the pointer on the right most line of the 3.
warndogg
The new one? If so take it off while in center (middle) position and manually move your vent until you only have air at floor then put the actuator back on and it should work.
Mma-007
