95 tahoe wipers stereo and hvac are out help!
95 2doehoe
95 2 door tahoe 5.7 tbi 4x4.
Im new to the forum I need help with my truck the stereo wipers and heater went out all at once I dont know if this is the right place to ask but I dont know where to start any help would be great thanks
SunlitComet
OBS Jedi-Do Good
unknown at this time.
so i added power and ground run diagrams for you in a pdf below since you said the fuses are good and a switch made no difference. you will want to look at the g1-- and g2-- ground connections.
can you also try something else please...
get a test light or meter and test for voltage on all the **** fuses using the body as a ground nearest the indoor fuse panel. put the positive side of probe on both sides of each fuse. if all have juice do the same to the fuses, using the same good ground, that apply to the systems that are down with the key in on or accy. post the results. from the looks of the diagrams if it was a minor ground point you should still have more systems knocked out. the test request above will help isolate the point of failure.
  • gmt400 1995 tahoe power and ground distribution diagrams.pdf
95 2doehoe
95 2doehoe
95 2doehoe
95 2doehoe
I did what you said and both fuses have power. So I decided to try something I powered the brown wire from the ignition switch with a jumper wire with 12 volts and the everything worked. So im guessing that the new ignition switch is faulty also?
Before this problem the hvac would work only up to the third level of the fan and I couldnt switch the vents or adjust the temp. When I jumped the brown wire everything worked on the hvac.
SunlitComet
OBS Jedi-Do Good
can you do the same but this time use both red wires going into the switch from the power box as the power source please. both connections are hot at all times. let me know how it goes. i just want to eliminate another cause.
95 2doehoe
95 2doehoe
When you say power box do you mean the fuse box on the side of the dash or in the hood? The wire I used to jump the power was from the ignition switch itself from where it connects to the ignition lock I took the cover off and one wire has power all the time and the other only when I turn the key.
dylansmashed
