homesick
The Best Me I Can Be
- Joined
- Sep 19, 2018
- Posts
- 1,895
- Reaction score
- 4,985
no on the sides, rear quarter panel i suppose it's called
What's the weakness?
Is there any effective preeventative precaution?
joe
I don't know really there is just a little water seeping from one of mine. The problem is you have to buy a whole new glass with the rubber to replace it. That's why I figured if I seal it from inside nothing else mattersWhat's the weakness?
joe
probably the best course of action is selling my tahoefor a while that will do the job. it will eventually trap enough dirt and water in there and rust it out.
I bought a tube of flowing silicone that im just going to use all the way around both sides of the seal. of course for the bottom sides of the seals I will have to flip the tahoe upside down so it flows into the seam instead of out of it. haven't worked out that detail yet. You guys think i could ***** it up into my big oak tree?unless your decent with a welder and have time to mess with it. i have seen the windows removed without breaking them. make sure its clean all around there use some new adhesive and you could seal it up. have to do something before it starts eating away at the truck. everything else is in solid shape and even if you just tossed some sealant around it it would take a little while before it started causing a problem. do a sealant patch now and fix it right later.
Did you blow out the water that was in there first?By the way thise rear quater windows arent hard to find at all. Lmc truck sells them, not cheap though. I used my flowing silicone and it sealed it up. Hopefully whatever moisture is behind there doesnt do too much damage because im not going to dig any further into this.
Also good news i didnt have to turn the truck upside down to get the flowing silicon to flow into the bottom of the seams, big relief.
Yes with compressed air and i let it sit in my carport for a weekDid you blow out the water that was in there first?
