Nightflyer
Hey Guys,
I'm Matthias from Bamberg, Germany. I've an 96 Tahoe (350 Vortec TBI) and a real big problem:
My car died three weeks ago while i'm driving (it was like, someone cut off the ignition) and won't start again. Nobdy in Bavaria and Germany knows why.....
- the battery is in a very good condition
- the car cranks very well but won't start
- the chevy has very good sparks
- the fuel pump is running and new
- fuel pressure at schrader-valve (is that the name?) is about 61psi and 63 while cranking
- changed the distributor cap, rotor, plugs and wires
- changed the ICM
- changed the CKP-sensor
- it misfires whit starting fluid (one time)
- the plugs are sometimes wet and you cann (sometimes) smell gas
- the timing chain is okay (tested with turning the crankshaft and look at the distributor..the rotor moves
sometimes it seems like, that the chevy would like to start. it sounds like, that there is no pulse to the injectors.
btw: there are no codes stored in the PCM and all cables ok.
Please: could someone help me? what can i test and look for?
Best regards from Bavaria/Germany
Matthias
p.s.: soorry fpr my bad english..
- changed the ICM
Matthias
