96 Yukon Drum Separator bar / strut bar / parking brake separator
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I threw mine out by accident once and the junkyard was the only option. I searched web sites for many many hours with no luck and I am damn good at it.
noJeepshere
Bountyfull, Utahrd
Hey if it's missing and you can't find a replacement, I feel it's a good excuse to upgrade to rear discs :Good or Bad:
Basically can't be bought seperately, so the boneyard is the only real way to go.
SunlitComet
OBS Jedi-Do Good
my thoughts exactly. just don't have the $1400 for the kit right now. besides I need to engineer the upgrade to work with a hydra-boost when i get that too.
---------- Post added at 03:51 AM ---------- Previous post was at 03:46 AM ----------
Easy conversion kit for drum to disc?
basically you tear of drum system, remove axles to remove backing plate. install new bracket adapters and reinstall axles with new seals and mount rotors and calipers. brake lines and parking brake linkage connections. bleed and enjoy.
mellowmike
