2003 z71 tahoe
ncalvo
ncalvo
FL
Please post the source, cost and removal/replacement process for the mirror. I have the same issue with mine.
will post details when I go to do it, but for now I am looking at rockauto part# BURCO 2734HSRSG
$44 it is the glass with backing plate, there's a video on the listing on reinstall. it has the turn signal but will not be auto dimming.
also I have heard be careful removing the mirror if the fluid gets on your paint it will permanently damage it
ncalvo
ncalvo
FL
I think a heater core replacement might be in my future
Last couple times I vacuumed my truck out underneath my front passenger carpet the bottom is moist with an oily/tacky film, no other symptoms
I've seen videos of hack jobs getting in the dash but I don't think I'll go that route, any other things to replace while I am in the dash?
Blend doors?
ncalvo
ncalvo
FL
ncalvo
ncalvo
FL
new evaporator, accumulator, and orifice, new heater core and actuators. I hope to never be behind the dash ever again.
I cracked my dash cover a bit when i tripped over my air hose and kicked it, not too happy about that. May have to try my luck at the junkyard for a new one, but its not too bad.
The job is done and my ac system holds a perfect vacuum again, just need to recharge it now.
ncalvo
ncalvo
FL
oil change today at 222,765 miles
got a quart of lucas fuel injector cleaner for $12 going to add to each tank see if it does anything
changed out my driver side mirror.....if you replace your mirror and it's distorted then push it in harder make sure all the clips are engaged
part number Burco 2734HSRSG
cpranger22
