The only way to pull 30 inches of vacuum is to be at sea level. Anything above sea level will be closer to 28" or less depending on the elevation.
FYI That's what happens when you have air in the system.Your volume is off no? 450 PSI tells me your overcharged
I recommend nylog. it is pag but in gewey form. I think I bought it off amazon.Oh and anywhere there is an oring, lube it with PAG oil before you put it back together.
