97 yukon p306 issue ??
SunlitComet
OBS Jedi-Do Good
unknown at this time.
http://www.amazon.com/MSD-Ignition-5592-Street-Distributor/dp/B004A6679S
direct replacement for any 5.0 +5.7l vortec engine no matter the model of vehicle. cap, rotor and cam sensor included.
seemed fitting as i already had wires, control box, coil and adapter harness. isn't it beautiful?
---------- Post added at 08:17 PM ---------- Previous post was at 08:09 PM ----------
and rotor attachment screws should lightly loc-tited before cap install. factory forgot that on mine and i forgot to check. one day massive pinging and stall on the freeway when rotor lifted and contacted cap and spun the assembly right of the shaft. http://s1222.photobucket.com/user/S...Tahoe 4X4/MSD Dizzy 1?sort=3&start=all&page=1
97blueyuk
97blueyuk
Going to do fuel pressure test, change the plugs, and check the distributor today or tomorrow. I'll do some research on the injector balance test and how to do it.
Thanks for the answers so far
SunlitComet
OBS Jedi-Do Good
need a pressure test unit and a scanner with gm bi-directional controls to tell the pcm to fire the injector while watching the gauge. you fire it twice and record your pressure loss. re-prime pressure and then another injector and so forth.
