98 Tahoe 2 door misfire.. Mechanics??
theautoman21
did you check your T.P.S also known as throttle position sensor, or map and or maf sensor and could be a sensor in transmission and check vacuum lines for leaks you can use a can of carb cleaner to check those just spray around the lines with engine running and if it stumbles you have a leak but these are just some basics to get you started
kevinw
