98 Tahoe 4wd Indicator Lights
MnDan
The 4wd / 2wd dash lights on my 98 Tahoe are not working properly. I pulled the fuse and reset the code and this worked for a few starts before they failed again. If I press on the 2wd button when I first start, it will normally engage, but it won't stay set (it may fail while driving, or on the next start). When the lights do work, I can hear the shift into 4wlo. Any suggestions on where to start would be greatly appreciated.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Reset what code? How do they fail? are there multiple lights on , light flashing code or continually? which lights specifically? What about the service light?
M
MnDan
More Details
1. Reset what code: The problem has not shown up with any type of “check engine” or “check 4wd” light. I rented a trouble code reader from my local auto parts store, but it did not show any error message. On another forum someone mentioned that a possible solution would be to pull the transfer case fuse and then reset the system by turning the key to the on position 4 or 5 times. When I do this, all of the lights engage upon startup, and then I the 2wd light turns on when the engine is turned on. Unfortunately, it has proven to be only a temporary fix. The light either fails while I am driving, or when I start the vehicle. When this happens, the light simply turns off – no flashing or other lights engage.
2. How do they fail: this can happen once I am driving, or when I turn the engine off and restart. Sometimes I can get it to light up if I press and hold the 2wd button, but normally only if I am in park or neutral.
3. Are there multiple lights on, light flashing code or continually? Which lights specifically? What about the service light? : Once the engine is started there is only one light on (i.e. 2wd, 4wd) or none at all.
Thanks for helping me with this - I am trying to do the repair myself, and need the 4wd to work reliably for the rest of the winter. When the lights are on, I am able to switch between drives, and can hear it switch into 4wlo, so I think the actually 4wd drive itself is functional. I hope this helps give you enough detail to think about what might be wrong. Let me know if I can give you more information.
OklahomaSideShow
