98 Yukon - Police Package? Yes/No?
saif najd
central point injection. all the injectors were housed in in a single body with lines to each cylinder with a poppet valve at each end. each cylinder got its own down the manifold runners. unfortunately the poppets mixed with low quality gas proved problematic. they have since redesigned the unit to work so much better. if you have the original injector spider in there do your self a favor if it has not been already and replace it along with your lower manifold to block gasket. if you had to state what were the major issues with the engine build it would be those along with maybe the distributor gear. not biggies really butt that covers how most of the engine failures happen. the new spider from amazon
delphi fj10566 http://www.amazon.com/Delphi-FJ10566-Fuel-Injector/dp/B000TYLIFS/
and gasket kit http://www.amazon.com/Fel-Pro-MS98000T-Manifold-Gasket-Set/dp/B000CH0C0Y
and bolt kit
http://www.amazon.com/dp/B0039SOMUE/?tag=k--20
will go a long way for the truck.
---------- Post added at 01:32 PM ---------- Previous post was at 01:31 PM ----------
sorry no carfax connections.
Thats a cool looking thing! But I have never seen such injection system like this what I know is the LS1 injection system and other similar systems
Could you please tell us more and how it could help the vortex engine? I have a 98 tahoe how or why should I fit this?
inthechateau
Maryland
Sunlit knows what he is talking about on the SFI. CFI was OEm and if you had any issues with O2 sensors, lousey performance or MPG then the CFI is the culprit. Did the conversion to SFI when I changed engines on my 96 and what a difference. Those are good prices in that link too.
Donnie Yukonie
Yates Caretaker
what does the speedo go to on it? 130mph was the easiest way to see if it was a police package..
x2 on this and 9/10 the police packages were "mildly equipped with creature comfort options such as heated seats and leather and the only 2 that I seen did not even have carpet in them but vynle flooring
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Thats a cool looking thing! But . Addahave never seen such injection system like this what I know is the LS1 injection system and other similar systems
Verry dlimited access for me right now here but i should add te upgrade is a drop in replacement if there was confusion on that.
audley71
