Hey all,
So I have read through several threads and see similar issues but nothing quite the same so appreciate any help.
The truck will start cold just fine, and will run for 15-20mins while parked and then just cut out. It doesn't sputter at all, its just a clean cut out. Once the truck dies it takes about 45 mins and will then start up again. In the mean time it will crank but not start.
I was getting P0300 & P0303 codes so started out by changing the spark plug in #3 which was bad, but still am having same issues. I cleared the codes after replacement but both codes have resurfaced. I have checked spark once the truck cuts out, and have spark to all cylinders. If I shoot some ether into the intake after it has cut out, the truck will start for a few seconds then die.
Also, when I first start up the truck(within first 5 mins or so) I am able to turn of the truck and restart no problem, but after about 10 mins of run time if I shut it of it will not restart. The issue seemed like it could be linked to a sensor/relay that was requiring a cool down period, so I replaced the cam & crankshaft sensors and the fuel relay hoping for an easy fix - no luck.
Its a pretty consistent cycle; starts fine, idles for 15mins, dies, and then requires a 45 min cool-off period prior to restart.
If I rev the engine it does reduce the run time before shut-off, but during the time it runs I am able to rev without issue.
I am going to pick up a pressure gauge today to check fuel pressure, but was skeptical of the pump being the issue since when the truck is running I am able to rev the engine without any hesitation or seeming loss of power. I have tried cycling the fuel pump several time once the truck dies to see if I can build fuel pressure, but it does not seem to have any affect. I replaced the fuel pump 4 years ago with a GMB pump and also just replaced the fuel filter. I'm hoping someone might have some suggestions, and I can avoid having to drop the fuel tank again. Are there any sensors that would inhibit fuel during a cool off period?
Thanks in advance,
Josh
Thanks in advance,
Josh
