Cranked it repeatedly. Tried mashing the pedal. Can't smell a whiff of gas under the hood. Both fuses look fine under the hood (injectors and fuel pump). I'm new to these trucks. Not sure where the tank is situated (dark outside now) but when I advanced the key to the forward position just far enough so the fuel pump should kick on (if that's how these Chevy's work), I couldn't hear anything underneath the rear end.
Truck has been sitting for two weeks (not started) on a slight incline (ass end down). Fuel level is between 1/4 and 1/2. I was thinking of letting her roll down the incline where I'm parked to level her off so I'd know for sure fuel was in the pump but I'm alone and would hate to try to push this beast back into the parking place myself.
Truck has run flawlessly since I replaced the intake gasket. Moved from Detroit to DC area without any issues.
Truck has 88K miles and I know in addition to the intake gasket leaks, these fuel pumps don't last but failing at only 88K???
I have a new Walbro TU435 which I believe is the same fuel pump used at the factory.
Before I call a wrecker, any thoughts?
---------- Post added at 07:25 PM ---------- Previous post was at 07:19 PM ----------
Forgot to add, before the trip I installed new plugs and new fuel filter.
---------- Post added at 07:36 PM ---------- Previous post was at 07:25 PM ----------
Also forgot to ask....how do you pull codes on these trucks?
