99 Denali caster camber problem
Woodse
Town Fair can't set my caster camber, they say the frame needs elongating for the control arm mount bolts. Can anyone explain how to?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
basically then need to punch holes in the control arm mounts up top to accept the bolts pictured below. afterwards those bolts turn those discs. as you turn each bolt the cam discs being held in the same place push the bolts in directions that move the adjustment or the control arm therefore adjusting camber and caster. every body has to get it done eventually.
99_Yukon
Michigan
Can you post a link as to where to get those bolts?
SunlitComet
OBS Jedi-Do Good
just hit up a local parts store for your specific application.
---------- Post added at 01:20 AM ---------- Previous post was at 01:11 AM ----------
a kit from moog should be #6302. that should fit the obs frames. the tool is here if you buy it on your own but jut let a shop do it since the control arm needs to be disconnected.
---------- Post added at 01:20 AM ---------- Previous post was at 01:20 AM ----------
oh and one kit per front side.
