99 escalade is in project mode
SunlitComet
OBS Jedi-Do Good
unknown at this time.
More parts, More parts!
Caution
This engine assembly needs to be filled with oil and primed. You should add the specified oil (see start-up instructions)
to your new engine. Check the engine oil level on the dipstick and add accordingly.
Start-up and Break-in Procedures
1. After installing the engine, ensure the crankcase has been filled with 10w30 motor oil (non-synthetic) to the recommended
oil fill level on the dipstick. Also check and fill as required any other necessary fluids such as coolant, power
steering fluid, etc.
2. The engine should be primed with oil prior to starting. Follow the instructions enclosed with the tool. To prime the
engine, first remove the distributor to allow access to the oil pump drive shaft. Note the position of the distributor
before removal. Install the oil priming tool, GM part number 12368084. Using a 1/2" dill motor, rotate the engine oil
priming tool clockwise for three minutes. While you are priming the engine, have someone else rotate the crankshaft
clockwise to supply oil throughout the engine and to all the bearing surfaces before the engine is initially started. This
is the sure way to get oil to the bearings before you start the engine for the first time. Also, prime the engine if it sits
for extended periods of time. Reinstall the distributor in the same orientation as it was removed.
After the engine has been installed in the vehicle, recheck the oil level and add oil as required. It is also good practice
to always recheck the CMP offset after removal and reinstallation of the distributor. See step 4 or engine specifications
for the proper distributor information.
3. Safety first. If the vehicle is on the ground, be sure the emergency brake is set, the wheels are chocked and the car
cannot fall into gear. Verify everything is installed properly and nothing was missed.
4. Ignition timing is non adjustable on this engine. The high voltage switch (distributor) must be installed correctly for
proper camshaft position (CMP) retard offset or the service engine soon light will be illuminated and DTC P1345 will
be set in the powertrain control module. (see GM service information for details)
5. When possible, you should always allow the engine to warm up prior to driving. It is a good practice to allow the oil
sump and water temperature to reach 180°F before towing heavy loads or performing hard acceleration runs.
6. Once the engine is warm, verify correct camshaft position (CMP) retard offset using a scan tool.
7. The engine should be driven at varying loads and conditions for the first 30 miles or one hour without wide open throttle
(WOT) or sustained high RPM accelerations.
8. Run five or six medium throttle (50%) accelerations to about 4000 RPM and back to idle (0% throttle) in gear.
9. Run two or three hard throttle (WOT 100%) accelerations to about 4000 RPM and back to idle (0% throttle) in gear.
10. Change the oil and filter. Replace with 10w30 motor oil (non synthetic) and a PF25 AC Delco oil filter. Inspect the oil
and the oil filter for any foreign particles to ensure that the engine is functioning properly.
11. Drive the next 500 miles under normal conditions or 12 to 15 engine hours. Do not run the engine at its maximum
rated engine speed. Also, do not expose the engine to extended periods of high load.
12. Change the oil and filter. Again, inspect the oil and oil filter for any foreign particles to ensure that the engine is functioning
properly.
13. Do not use synthetic oil for break-in. It would be suitable to use synthetic motor oil after the second recommended oil
change and mileage accumulation. In colder regions, a lower viscosity oil may be required for better flow characteristics.
Ceejkay
Ceejkay
Ft. Lauderdale, FL
thanks sun. i looked for that and couldnt find it.. not going to have much of an update today.. im gonna get the engine bay all cleaned up and a few other things done..
---------- Post added at 08:58 AM ---------- Previous post was at 07:30 AM ----------
so do i really need the special priming tool or can i just cut the handle off a flat head screwdriver and attach it to a drill??
Ceejkay
Ceejkay
Ft. Lauderdale, FL
alright i found autozone has one they rent for 30$ that is refundable when i bring back the tool.. works for me
jmyler
atlanta
even better! no need to mess around with maybe's when doing something like an engine swap.
katokaato
