99 Tahoe - Mechanics Special
Brandon X
Michigan
Well I got my tahoe on craigslist for the weekend and figured I might as well post it on here for anyone interested. I hate to sell it, but I gotta. Most of you should know how much money ive put into this thing and it's a steal at this price especially if you're a mechanic.
I have for sale my 1999 Chevrolet Tahoe LS 4wd. TONS of custom parts (ill list below). Absolutely babied for the entire time ive owned it. Synthetic oil changes, premium gas, etc. Has 175k on the odometer, and the reason why im selling it for so cheap is because I recently just found out there's a small crack in the block by the starter. In this last month alone after replacing the starter twice, starter gear once, and the flywheel, I was finally told this is the problem. The truck runs EXCELLENT, but what happens is when I try to start it there's a grinding noise, and it's because the starter is flexing just a tiny bit because of the small crack in block. Atleast this is what ive been told by a mechanic. Now if you know how to weld cast you could weld it, or you could replace the whole engine which is what ill most likely do if nobody buys it this weekend. If you buy it and you wanna replace the engine I can tell you where you can get one with 80k miles for $1050 + core from a junkyard. Here is all the custom parts ive put into it:
Performance:
Pacesetter Longtube Headers
Custom True Dual 2.5" Exhaust Dumped Before Rear Axle w/ No Cat
Borla ProXS DI/SO Muffler
Ported Throttle Body
PowerSlot Rotors, Hawk LTS Brake Pads & Russell Stainless Steel Brake Lines
Spectre Cold Air Intake
Black Bear Performance Tuned PCM
Optima YellowTop Battery
MSD Coil, Cap, Rotor & 8.5mm Super Conductor Plug Wires
NGK Laser Iridium Spark Plugs
Magnetic Drain Plug
Suspension:
3" Rough Country Suspension Lift
Nitro 9000 Rough Country Shocks
Poly Swaybar Bushings
Moog Ball Joints
Exterior:
33" Goodyear Wrangler Duratrac Tires (Less than 6 months old, have receipt from Belle Tire)
15" Cragar Soft 8 Black Rims
Rollpan
Painted Smooth Front Bumper
TYC Elegante Clear Headlights
TYC Elegante Clear Parking Lenses
Clear Corners
DDM Tuning 6000K HID's
Billet Grille Inserts
Billet Bowtie
Color Matched White Grille & Mirrors
Smoked Taillights
Undercoated w/ Herculiner
Interior:
Blue Interior LED's (Cluster, HVAC, Courtesy, Doors & Dome Lights)
White Interior Trim Pieces, Vents, Fuse Cover & More
Audio:
Pioneer Premier DEH-P510UB Head unit
2 DC Audio Level 2 15" Subs
4th Order Bandpass Box (Made by me & designed by a professional)
Kicker ZX750.1 (Sub Amp)
Kicker KS650 Front & Back Door Speakers
Kicker KS4100 Rear Roof Speakers
Kicker ZX650.4 & ZX150.2 (Speaker Amps)
XS Power 2400w AGM Powercell Battery
KnuKonceptz Karma SS 10g Wire (Subs)
Raptor 0g Wiring Kit (Distro blocks, 200 amp fuse holder, terminals, etc.)
Big 3 Done Using 0g Wire
Kicker Double 0g Positive Battery Terminal
Removed/Shaved:
Roof Rack
Running Boards
Antenna
Side Moldings
Badges
Chrome Wheel-Well Moldings
3rd Brake Light
Front License Plate
Tow Hooks
The first 2 pics are how it looks now, and the last two are how it looked in the summer when I had 26s. Taking $3500 cash, and no im not selling any parts off it. Got clean title in hand. Send me a message asap if interested. And like I said if I don't sell it this weekend im keeping it and putting in the new engine.
Brandon X
Brandon X
Michigan
Well nobody bought it. Had a few calls but nothing went through so im just gonna fix it and sell it in a couple weeks with it running.
johnnnyb63
