99 Tahoe p0420
chitown906
Came back from Appleton wi and the HOE is giving me a P0420 ( catalyst system efficiency below threshold bank 1) and a secondary code is identical but pending ..
What is the issue?
Chi_town
Freedom Motorsports
The system is reading too low flow through the catalytic converter on the driver side. You probably need to take it and have the cats checked.
C
chitown906
That's what I thought it may be, I reset the computer so hopefully it goes away. It was random we fueled up and the code randomly came on.
I know a stock cat is like $400 what does a aftermarket car run? Or has anyone here just removed them without any negative results?
C
chitown906
Now when purchasing them , do they come as a set or each?
C
chitown906
Ha yeah I may look at other avenues , as of now the light is out so if it comes on again I'll bring it in and see what that gets me. It came on right after we filled up at a shell station , could bad fuel bring on the light?
Chi_town
SunlitComet
OBS Jedi-Do Good
unknown at this time.
What is the issue?
Chi_town
CIRCUIT DESCRIPTION
In order to control emissions of Hydrocarbons (**), Carbon Monoxide (CO) and Oxides of Nitrogen (NOx), The system uses a three-way catalytic converter. The catalyst within the converter promotes a chemical reaction which oxidizes the HC and CO present in the exhaust gas, converting them into harmless water vapor and carbon dioxide. The catalyst also reduces NOx, converting it to nitrogen. The Vehicle Control Module (VCM) has the capability to monitor this process using the HO2S (Bank 1, Sensor 1). The HO2S (Bank 1, Sensor 2), located in the exhaust stream past the three-way catalytic converter, produces an output signal which indicates the oxygen storage capacity of the catalyst; this in turn indicates the catalyst's ability to convert exhaust emissions effectively. If the catalyst is functioning correctly, the HO2S (Bank 1, Sensor 2) signal will be far less active than that produced by the HO2S (Bank 1, Sensor 1). If a problem exists which causes the VCM to detect an excessive HO2S (Bank 1, Sensor 2) activity outside of an acceptable range for an extended period of time, the VCM sets the DTC P0420. This DTC indicates that the three-way catalytic converter's oxygen storage capacity is below a threshold considered acceptable. This is a type A DTC.
gscherer78ta
I recently had the P0420 and then shortly thereafter the P0430 codes come up. I replaced my O2 sensors- all of them. I haven't had the code come back up since, roughly 400mi.
Now, I had never replaced the O2 sensors and the '99 Tahoe has 164Kmi.
Just sharing my experience.
Greg
Mikejuarez
