99 Tahoe will not start
jeff sanford
When you turn the key over nothing happens. I have check all the fuses and everything I can think of please give me some ideas. I came out of the store and it would not do anything. If you turn the ignition to the on posistion everything works fine, but when you try to start it it does nothing. I had to use a screwdriver to jump the solenoid at the store to get it back to my house. Thanks
retorq
Kingman AZ
Well if you jumped the solenoid and it worked it's probably not that. Pull the wires off the starter and test them with a meter and see if they are good.
TigerEyz3
Slow and Steady
TN
Could be the starter relay since jumping at the solenoid bypasses it (starter relay).
Rkelly1224
