i know there are a ton of posts on misfires but I thought I would start my own thread for my specific case. Ok so here is what I have done already. New maf new o2's new plugs wires cap and rotor new pcm new valve cover gaskets. I have always had the cylinder 4 misfire and had a bunch of codes with it before. I have since fixed all the other codes. I have a random coolant leak that I cannot see anywhere and a leak down test proves the the system is in fact leaking but still no drips on the ground or anywhere on the motor. It's also running a bit lean 8.9% bank 1 2.7% bank 2. It was 25% on both banks and I fixed the major leaks where it was the valve covers and the top of the throttle body. I suspect my lower intake is leaking the coolant and making the motor run lean. Also I checked the spider injector assembly and it is in good condition. I was wondering if anyone could point me in the right direction and if you think the coolant leaking through the intake (if that is the case) could be causing this misfire
