99 yukon ignition issues help!! only source of transportation for a family
netdrop
99 yukon over 100k miles
Transmission swap reused the torque converter.
Fully charged battery.
Alarm disabled and truck was able to run after doing this.
Able to jump across starter and engine will try to start with or without the key in place. Engine will continue cranking even if key taken out.
Clock and radio lights work.
Checked fuses both in panel on drivers side and under hood. All seem good.
Won't crank or shut off with key. Not sure what the problem is. HELP!!!
This is my son and wifes only transportation to get back and forth to work. Need help ASAP.
blue wire in engine bay behind distributor with no location to go to.
bigfootchiro
Largo, FL
Can you take a picture of the wire? Could be an ignition switch issue; however, I have not heard of that issue before.
devingcore
