99 Yukon - no start
hga1148
ARK
okay so friday night, i left my lights on in my 99 yukon 4 door 4x4 and now after a full charge, all the eletronics work and it tries to turn over but it won't and i sprayed started fluid into the gas line and she started til that burned up in like half second and died again so im thinking my fuel pump went out but just to make sure i didnt reset anything after my bettery died because that was a coinentidental timing on it quitting out, i didnt wanna pay $400 for a new pump and have that not be the problem, any thoughts or suggestions?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
using a good sized jumper wire with vehicle ignition system off apply battery direct 12v to the A3 terminal on the under hood block with your fuel pump relay removed(in picture below) and listen fo ryour pump running. It is a direct line to pump. You will now right away if it is the pump or computer(has total control in the 99's).
CAUTION the image is from the bottom looking up so don't mess it up.
QUYHMK
