99 yukon
patrick99yukon
I have a 99 Yukon with some issues hoping for some helpful advice.
A whining/ light grind coming from somewhere? Fairly steady howl thru out all gears and completely stops as soon as the gas pedal is released.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Sounds like differential problems causing maybe all the concerns. If you can do it look at the fill plugs of both diffs and see what the fluid looks like. Metal in it? Grey in color? Smells burnt? Does it make a difference in 2wd as opposed to 4wd?
qukon 95
IT sounds like rear end issue mainly the bearings. chuck front tires,jack up the rear axle until wheels clear ground , then put jacks under axle ,start up,need two poeple put n drive BUT go easy pressing down on gas peddle under rear just listen i use a stick like a stethoscope move it around to pin point the noise.
Meg_az19
