CGKirk1104
Ok so I'm fairly new here, and I want to thank everyone for the wealth of knowledge that has allowed me to fix A LOT of problems I have been having with my hoe over the past year. But now I have another one. So here it goes:
I have broken 2 A/C belts in the last 2 months. When the belt was on the AC compressor, it would run ok, but then with low idle or even low rpms it would make a terrible sound that reminds me of the sound a leaky exhaust manifold makes. It will make the sound for a while until it either changes gears or the rpms go up a bit it seems. But then again it happened quite frequently with the AC going. It does not go when the heat is on, so that narrows it down to the AC system. However, I have no idea what could be the problem. My guess is either a AC compressor clutch is gone, or I need a new compressor. Has anyone had this problem before? If so what do I need to do to fix it?
Any help is GREATLY appreciated, it was 97 with heat index of 105 today in Louisville, KY so driving my black truck in the heat and sun is VERY uncomfortable!!
