A/C issues
shegarty
Hey all - I'm currently trying to get ahead on the warmer weather and get caught up on overdue maintenance on the truck (04 Burb LT). Last year on a road trip we lost a/c when the bearings went on the pulley. This fried the magnet and the clutch. I managed to get the whole front end of the compressor (clutch, pulley and magnet) replaced with a good unit from the salvage yard. I opted for this route since the system was still holding pressure and the compressor on the truck would still turn freely. I didn't want to evacuate the entire system to replace the whole compressor as the truck has rear a/c as well and the cost to refill is a bit prohibitive.
The issue now is the the truck will not engage the clutch either when directly called for (snowflake button) or when using defrost. I have checked resistance on the electromagnet (around 3.5 ohms) and continuity (passes). I have also tried jumping the clutch directly with 12V and it does engage. I have replaced the old blown 10A fuse and already tried a replacement relay. The low side of the system is sitting at around 30 psi which should be okay since ambient is only around 5ºC (41ºF) right now.
Any ideas on what I should be looking at next? Low/high pressure switches? Other wiring issues? Adding refrigerant?
Multnomah Falls
My first guess would be the low pressure switch at the accumulator. The high pressure switch is in the back of the compressor and typically hardly ever go bad. When you do supply the power to the clutch and the compressor does engage, what are the pressure readings? High and low side. I would not add refrigerant till you tell me what the high and low pressures are when clutch is engaged and the compressor is activated. It may just be seepage of refrigerant and the pressure is low. Typically the static low pressure and static high pressure can be the same when attach gauges at the lines with the engine off. It all correlates to the ambient temp outside. The higher the ambient temp, the higher the static pressure. For instance, if you look at a pair of a/c gauges you can see that if the ambient temp is about 85 degrees then the static pressure will be about 15-20 psi higher. This is all on a fully charged a/c system.
If, like you stated, the ambient temp is 41 degrees, the static low pressure should be a bit higher than the ambient temp reading. Based off all that, I would say the system is low. You may still have a pressure switch problem, but I doubt it. Unless the previous clutch failure caused switch damage that weakened it and is now also a problem. Low pressure switches are cheap. When you charge the system, put a new low pressure switch on the rig.
https://www.rockauto.com/en/moreinf...U6/ShSVVud2qRWhoP65Xzc0NjW5n0fcow5FK66+OC3pG6
S
shegarty
I didn't engage the clutch with the engine running as the connector is in an awkward location and I didn't have pins or alligator clips to make a secure connection. At the time I was more concerned with checking the functionality of the replacement magnet/clutch assembly. I will look at getting a low pressure switch and then think about topping it off when I do some a/c work on one of my other vehicles. To add to the problem the previous owner appears to have removed the schrader connection on the high pressure port so I can't get any readings from it. It looks like the valve was replaced by some sort of rubber seal.
Sent from my LG-US996 using Tapatalk
Multnomah Falls
Post a pic of that high side port. I have never heard of such a thing. The pressure at that port is a lot when system is running. A threaded shrader valve will hold it but have never heard of a different way to seal it.
S
shegarty
I've never seen anything like this before either. Looks like a rubber seal under the top part of the fitting.0b390efe38cc9df1ca8d6a6c9421f371.jpg
S
shegarty
Outside looks just like a normal fitting1b14e3b870a343abe87f7f86fbeebbf6.jpg
ks03
Fool Excess Member
I believe it’s a ball valve, if you look at the inside of the fitting on your gauge set, you should see a 1/8” or so post that will depress that black part in the fitting on your vehicle, when the gauge set fitting is screwed down
Multnomah Falls
Ok, so I went to look at my 2002 Tahoe and I found two fittings on the high side line. The furthest forward had a fitting like this one you have and the one closest to the accumulator, in the same line, had a normal shrader valve fitting. Do you have 2 fittings in the same line? Here are very poor lighted pics but in one of them you can see the two fittings in the same line.
S
shegarty
View attachment 245019 View attachment 245020 View attachment 245021
Yes there are two fittings on the same line but they are on opposite sides of what i understand to be the expansion valve making one the high side and the other the low. The high side is the one closest to the engine and the low closest to the firewall with the expansion valve in between.b326e6a4c0a5fd1eb1ec1c578126850f.jpg
Reed198899
