swampslider
96 Tahoe. The A/C works fine in 80 deg. Weather. At 94 and up, it will work as long as your moving but heats up if your sitting for a 15 to 20 min. period. Also if you shut everything down for 30 min. The clutch will not come on. I replaced the High pressure switch but it still wont engage. it will remain that way for hours till it cools off completely. The low pressure line is as hot as the high pressure line
This morning I put a cheap gauge on the low pressure side. At start up it was at 25 psi and rose to 35 psi after 1-2 min. At this point I revved the engine the pressure dropped below 15 psi and the clutch disengage. After returning to idle the clutch reengaged after 3-4 seconds. When idling the cab temperature from the vent was 40 degrees.
Any ideas on what could cause this.
Thanks in advance for any input.
