A/C not working
St Nick
Columbia, SC
I took mine to the dealer...he said there was a service bulletin on the "overcharged" A/C issue. I haven't had it happen again....although it's only been 6 days.
smittydog
A/C
Ok..I have 7K miles on my Yukon. Yesterday we drove 3 hours (170 miles or so) in 91 degree heat (low humidity) and the A/C worked great. I shut the engine off at my house and took 10 minutes to load a cooler with ice and gator aid , then started her up again to take my daughter to horse back lessons. The A/C stopped working. ARGH.
I will be dropping it off to the dealer for troubleshooting. I already had an appointment for a recall on the instrument cluster and the transfer case.
I'm just hate the heat and frustrated that this could/has happened.
GM Customer Service
Michigan
Hi smittydog,
I understand you are frustrated that your air condition has stopped working on your Yukon and I do apologize. You mentioned that you are planning on getting your vehicle to the dealership for this concern. Please keep us posted and contact us if you have any lingering questions or concerns.
Jennifer T.
GM Customer Care
smittydog
A/C Update
dealership called me back. It seems the reason my A/C failed is a rock put a hole in the condenser up front.
Really? What are the odds? Now, this is my first GM product (never had a rock come thru the grill on my other vehicles). The front of the grill and it is very open. $800.00 estimate from them. Holy Cow....
So, next question, how can I prevent this from happening again? Do I need to change grills?
This sucks....just need to vent.
Thanks,
Steve
Jproy
I did the same thing once in my pathfinder. Set me back ~$600
RShelvy
2015 Yuukon AC Issues
Like the Tahoe apparently, the 2015 Yukon has AC Problems as well. Bought it new three months ago and have 2000 miles on it. When started with the remote or manually the AC blows hot air even after driving several miles.
To remedy this, I have to restart the truck several times or manually turn the AC off and on several times. After being aggravated with it, I took it to the dealer today. At the end of the day, the Service Manager called and said they could not find anything wrong and the AC was working fine, when they started it.
I explained that this happens intermittently and has occurred at least thirty times since purchasing this truck. This is my third Yukon and I've never had an AC issue until now.
I'm at a loss here. Sure would like some help from GM Customer Service.
GM Customer Service
Michigan
Hi RShelvy,
Can I be of assistance? I see that you mentioned that you are experiencing an issue with the Air Condition system in your Yukon and I do apologize. I would be happy to discuss this further. Could you please private message me referencing this thread?
Jennifer T.
GM Customer Care
2GlidePath
I have a 2015 Yukon and am having the same A/C problems. The A/C works intermittently. One day the entire vehicle would blow nothing but hot air and the only way to get it to blow semi cold air was to shut off the rear unit. Today the front unit works fine, but cold air will not blow from the rear unit. This is not something I expected from a vehicle as pricey as the Yukon, but I am taking it to the dealer today for evaluation. Lets hope they determine what is wrong with it and don't tell me it is nothing. I live in Texas and the 100 degree days are in full swing. I did not purchase a new vehicle to only be able to drive it in the winter.
Tahoe14
Central Fl
When I picked up my new Tahoe about a month ago they were taking three new ones off the line and into service for AC issues. Said they were over filled from the factory. Some of these issues in this post sounds like different issues. Please keep us posted in case we run into the same problem. Good luck with your repairs.
carloogbuyNuh
