A/C performance lackluster
SnowDrifter
Washington. The starbucks side not the desert side
Aaaand here we have another a/c thread. HVAC stuff isn't so much my area of expertise so bare with me.
I turned on my air conditioning the other day, it wasn't blowing all that cold. It worked, but really not as well as you'd expect. Vent temps only a few degrees below ambient w/ max a/c. I dug out the manifold gauges to see what the pressures were doing and found I had a leak from the low pressure schrader valve. Ok no biggie. I replace the valve, vaccuum the system, check it holds pressure. 20 minute vaccuum, no change. Filled it up with 2.7lb refrigerant (no stop leak crap. Just plain r134a).
Low/hi pressures are around 40-45/175-200 @75 degrees. Nothing out of the ordinary there, but even still, the a/c just doesn't blow cold. It blows cool, not cold. Again, just a few degrees below ambient. Same thing for driver's, passenger, and rear vents.
This has me stumped. I considered a blend door, but then why would that effect the trifecta of driver/pass/rear? Unless something's wonky and they are ALL bad? I have no idea where to go from here.
2005 Tahoe LT w/ rear a/c and auto climate.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
can you physically see the compressor engaging? Might have a electrical or compressor issue
sumo
rhode island
Still could be compressor. Possible relay, after it gets warm it shuts off. When it goes out check to compressor and see if it's still kicking over. Maybe excessive clearance between compressor and clutch?
Beefsolar
