Runninglate
Hi guys, I'm new here and I'm having an issue with my A/C.
I have a 1998 Yukon 4x4 with rear a/c. Ever since I purchased it 11 years ago, the a/c has slowly been getting worse. It has always had a slight freon leak, even when it blew really cold air.
It was tolerable until last year when the front and rear a/c started blowing hot air.
This year, I added a little freon (it was low enough that the compressor wasn't spinning), and the front a/c started working. It only cools the air about 10-15 degrees below the ambient temp when at highway speeds. It barely cools at all while at idle. The rear doesn't blow hot air anymore, but instead blows ambient temp air.
I cleaned out the condenser as good as I could by spraying it with water, but that didn't help my problem.
I hooked a set of gauges up to the Yukon and my readings are as follows:
- Static(engine off): high side 120, low side 115
- Idle speed(600rpm): high side 145, low side 74 (both needles were fluttering heavily)
- 1500 rpm: high side 160, low side 48 (needles were barely fluttering)
- 2000 rpm: high side 155, low side 42 (no fluttering)
The ambient air temp was 96 degrees and the humidity was 40%. Also, the compressor never cycles, it is constantly running.
Any thoughts on what could be wrong? Thanks!
