went to get the downloads and it wanted me to download a game is that correct?
Probably not! Usually thats a sign of a virus or malware in your system. Thats always been a good site 4 me.
Try post #111 in that link. It looks like another member posted another 1999 copy onto a Google drive.Thanks for the information and the diagrams I replaced the high-pressure switch and have the other 2 on order. I’ll post what I find. went to get the downloads and it wanted me to download a game is that correct?
Got the service manuals and they were a big help. Also found info on the Chevy forum. I have changed all the sensors and replaced the plug and diode for the clutch and plug for high pressure switch. The compressor will run now for about 5 sec an shut off for about the same period of time and then repeat the cycle for about 5 minutes. If I shut he truck off and let it cool down for an hour or so when I start it again it will do the same thing again. The ambient temperature is about 65 Humidity around 55 low pressure will drop to around 25 and then go back up to 60, the high pressure will go up to about 80 and then down to around 60. I don’t know if it’s low i put 5 12 oz cans in and I don’t want to blow the seal out of any thing. Any suggestions?Try post #111 in that link. It looks like another member posted another 1999 copy onto a Google drive.
Yes I do. What should I be looking for on the accumulator. I'll check the Temps Monday we have company this weekend. ThanksDo you have a laser thermometer? While compressor runs, shoot temps upstream/downstream of each component.
Also look for charge sticker usually on accumulator.
Pressure drop lowers temp, so if there is an obstruction, say from a failed compressor or a clogged oriface valve..... every piece in the system has a change. So a Big change or a No change is something to think about.Yes I do. What should I be looking for on the accumulator. I'll check the Temps Monday we have company this weekend. Thanks
