A/C vent air volume not blowing strong.
83 Bimmer
Edit, didn't read everything, never mind
Sent from my HTCONE using Tapatalk 4
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Sometimes the seals between the ducting parts can leak over time. The motor and linkages for the output mode door assembly is visible along side the top of the accelerator panel. The blend door is really a temperature selection door.
nimrod.sixty9
nimrod.sixty9
Hold on, I got this.
Okeechobee, FL
Not sure what you mean by motor and linkages or accel panel
SunlitComet
OBS Jedi-Do Good
#'s 11, 27-29 in the pic below put your head on the drivers floor board. Look at the "gas" pedal and the look higher up.
nimrod.sixty9
nimrod.sixty9
Okeechobee, FL
Thank you good sir. Im not around the truck right now, but I can picture the area and Im almost certain I have felt a breeze. So a pressure loss thin then?
Blesna
