This Youtube video helped a lot, I wish it had better lighting though when the technician showed how to put in the spider gears. I suggest watching the video first. You can't put BOTH spider gears at the same time because the other two bigger gears spin in opposite direction.
Basically, here is what I did. The first one is super easy to put in. You should put that first spider gear on the top. Once you have one spider gear aligned up with the hole, move it forward almost to the point that it will drop, but not quite yet. While holding the top gear to prevent it from falling, put the second gear on the bottom, move it forward, which will make the top gear move back. You know you got it when the all the holes line up. You will have to experiment and fiddle with it for sure. It's really hard to explain, but the youtube video explains it a lot better than I even can.
But I still can't get the goddamn c-clips off!
I give up, I'm bringing some help.
