As a professional HVAC and refrigeration tech. I am happy to share how to go about properly troubleshooting the single and DUAL AC systems.
First off, dealing with the refrigeration system in anyway can be dangerous if you dont know what you're doing. I am not liable for anyone's actions. This is meant as a guide
As with starting with ANY AC issue, the very very first thing to check is AIRFLOW. you should have good strong airflow through the panel vents as well as the rear unit as well. In addition, ALL mode doors must work properly and most importantly the Blend and recirculation doors. On full cold they must COMPLETELY block the path to the heater core. This is a 100% must and you WILL chase your tail on a problem if you cant verify this.
Once you have confirmed proper operation of the system electrical wise, and you still have lack of cooling,....NOW...you may move to the actual refrigeration system in the car. I will be explaining how to trouble shoot lack of cooling, and basic issues you encounter. Description of the auto and dual climate systems I will do separately (not in this thread).
To begin. I do NOT condone using those stupid cans with cheap/lame charging hoses that only connect to the low side. Using this WILL get air in your system. You will cause more problems and...again..chase your tail.
Either educate yourself and do the job properly, or have someone who knows how to help u .
The best thing about ALL vehicles is they are a WEIGH in charge. Right on the hood they say.. "takes x.x pounds of 134a"
Our SUVs with rear AC take roughly 3lbs of refrigerant. They need that EXACT amount...not 5 oz more...not 5oz less, but that charge.
Begin with making sure that that amount is charged into the vehicle and that will help you determine what the issue is.
Next... make sure that clutch radiator fan is moving air!!! That dumb thing better be Mooooving air when its hotter than blazes outside. If... its screaming hot outside and your engine is hot and the AC is on...its gotta engage on high speed otherwise you'll have crappy cooling. A symptom of this would be poor cooling in stop/go traffic but getting better on the highway. Replace clutch with the GM clutch, not aftermarket or better yet do the electric fan conversion and you'll kick ass cooling while at idle.
If you have weighed in the charge (which includes a proper pressure test and evacuation... get someone to do this for you!!!), you can then narrow down on what the problem was.. IE: low on charge, overcharged, failing condenser coil, weak compressor or failed metering devices.
My next post will go over some general troubleshooting tests that cover specific symptoms.
Sent from my SM-G975U using Tapatalk
